Author Topic: Battery came out of place  (Read 1134 times)
Offline Snap
  • Just smile, stop being miserable!! :-)
« on: 08 February 2007, 18:13 »
For the last couple of days my coolant temperature light has been coming on more frequently than usual. I know its a common golf problem but it had been coming on from as soon as i set off. So i thought i would at least check my coolant bottle. The coolant level was fine, in fact it was over the max line.
I then noticed the battery was out of position and resting against the fan blade, possibly the reason for the light coming on maybe?? Anyone had this problem?
« Last Edit: 08 February 2007, 18:17 by Snap »
'92 1.8 Mk2 Golf, carbed GU... [SOLD]
sacvwgolf
Re: Battery came out of place
« Reply #1 on: 08 February 2007, 18:23 »
is there a clamp on the battery - there should be.
Offline dubslug
« Reply #2 on: 08 February 2007, 18:26 »
if the fan blades jam the car may over heat due to the fan not kicking in??
1992 pearl grey 8v
Offline Snap
« Reply #3 on: 08 February 2007, 18:33 »
Nope, i need one. Yep im worried about the engine overheating.
Offline dubslug
« Reply #4 on: 08 February 2007, 18:36 »
there should be a metal clamp on the front of ur battery, held in by 13mm bolt
1992 pearl grey 8v
sacvwgolf
« Reply #5 on: 08 February 2007, 20:07 »
what he said /\/\, u should have one other wise the battery will be all over the place.
Maybe the battery was stopping the fan from moving.
Offline Snap
« Reply #6 on: 09 February 2007, 01:58 »
Yep i was thinking that too.
Offline Gambit
« Reply #7 on: 09 February 2007, 13:40 »
get a clamp & bolt of a scrapper. and also stick a square of carpet under the battery. this will stop it sliding
