Author Topic: mk3.5 cab clocks in mk3  (Read 957 times)
Offline anthony_caddy
« on: 07 February 2007, 19:19 »
hi guys, i am thinking of fitting mk3.5/4 cab clocks in my 1.6 cl. does anyone know if theya will fit straight in, and also what the going rate is?
cheers folks
Re: mk3.5 cab clocks in mk3
« Reply #1 on: 08 February 2007, 12:31 »
yes they'll fit, just make sure its from an 8v engine or the rev counter redline will be off.
Main thing to worry about is the speedo drive, I don't know if all MK3s have an electronic speedo?  If yours has a cable driven speedo you may need to fit an electronic one to make the speedo work.
Only other issue is the milage, its very hard to change on MK3 clocks!
