Author Topic: golf clocks  (Read 2201 times)
Offline oldbealmk2
golf clocks
« on: 07 February 2007, 18:53 »
i got a mk2 golf 1.3 1996 nd just bought sum new clocks with rev counter out of gti i think but will it just got straight in or will i need extra wiring for the rev counter to get that to work?
Mk2 work in progress
Re: golf clocks
« Reply #1 on: 08 February 2007, 12:30 »
1996? :wink:
If you get the right model clocks, they'll plug straight in and work.  If your hazard switch is on the dash, you'll need 2 plug clocks, and if the hazard switch is on the column you need single plug clocks.  The MFA wont work without the stalk and a bit of wiring, but without the stalk the MFA will just display as a digital clock :)
Offline oldbealmk2
Re: golf clocks
« Reply #2 on: 08 February 2007, 13:33 »
ok mate cheers my hazards are on the dash and the clocks im fitting have a plug for speedo and a plug for rev counter so they wont fit straight in then?
Re: golf clocks
« Reply #3 on: 08 February 2007, 13:46 »
Early 2 plug clocks (hazard switch on dash)
http://cgi.ebay.co.uk/VW-MK2-Golf-GTI-8V-Double-pin-dashboard-clocks-EX-CON_W0QQitemZ110089227880
Late single plug clocks (hazard switch on steering column)
http://cgi.ebay.co.uk/volkswagen-vw-golf-mk2-gti-16v-g60-rallye-clocks-160mph_W0QQitemZ180083562496
If you have the hazard switch on the dash, you'll need the early 2 plug clocks. I take it you meant to say 1986 yes?  If so that will defo have the early 2 plug clocks :)
