Author Topic: audi throttle body  (Read 1605 times)
Offline ian007miles
audi throttle body
« on: 05 February 2007, 22:12 »
hi can any 1 help me i was thinking of buying an audi throttle body (for performance resons :grin:)and fitting it on my mk1 golf gti 1800 and i was wondering if there was any fing else that i need and how would it make the car run thanx ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline BobbyT
Re: audi throttle body
« Reply #1 on: 07 February 2007, 08:34 »
hi mate, you will need to match the inlet manifold for the new throttle body, use a dremel to grind some metal off the inlet holes so they match the size of the throttle body inlets!  :smiley:
Offline ian007miles
« Reply #2 on: 07 February 2007, 15:21 »
thanx Toofunkyhouse so will it make much of a differance in power and speed . oh and does any thing else have to be modified on the inlet manifold or the throttal body?
Offline BobbyT
« Reply #3 on: 08 February 2007, 05:28 »
well i did notice a better pick up, it made it rev out a little quicker, combine this with a new filter and you should see a few more horses! its a pritty easy mod to do, once you have ported your inlet manifold just bolt the new one on! and enjoy!  :grin:
Offline ian007miles
« Reply #4 on: 13 February 2007, 10:18 »
hi ive just received my audi throttle body and ive noticed it has a manual choke and my car has an altermatic choke wot shood i do to make the choke workor is ther a way round it thanx in advance ian
