Author Topic: ET12 offset wheels?  (Read 810 times)
Offline mk2mark
ET12 offset wheels?
« on: 04 February 2007, 21:50 »
Will et12 wheels be undriveable/rub on a mk2 lowered 40mm? What's the standard offset?
Offline mk2mark
Re: ET12 offset wheels?
« Reply #1 on: 04 February 2007, 21:55 »
Whoops that's not really enough info - the wheels are 15"x7 wide, I'm concerned about how it will affect the handling - is anyone running anything close to this?
« Reply #2 on: 05 February 2007, 10:53 »
Standard offset is 35-38, 24 is about the lowest you can go without serious rubbing issues.  With ET24 beemer wheels on mine the rear was fine but the fronts rubbed on harsh bumps & uneven cambers.
I have ET28 7j wheels, the front is fine but I've got 16mm spacers on the back which work out to ET12, and I need to bash my arches in a bit as it now rubs over bumps and with people in the back!
Edit: This is after lowering 40mm though...
« Last Edit: 05 February 2007, 10:55 by rubjonny »
Offline mk2mark
« Reply #3 on: 05 February 2007, 12:29 »
Cool, great info - have you any pics? How did it affect the steering changing the scrub radius like that?
« Reply #4 on: 05 February 2007, 12:32 »
I didn't notice any difference after fitting the ET24 beemer wheels, and only my back wheels are ET12 atm.  I only fitted the spacers because I couldn't get the centre caps to fit over the rear bearing dust seals :grin:
I know it would be a mission to fit em up front, would need most of the metal chopping out I'd expect!
