Author Topic: Fitting 16v master cylinder  (Read 793 times)
Offline mattp1983
  • Keep it VAG :)
« on: 04 February 2007, 18:50 »
I am about to fit a mastercylinder from the 16v to my 8v, I have the calipers, carriers and discs as well, was going to do them all together, now I know its difficult to get to the servo area, having to take airbox and pipes out, I was wondering if there is anything I need to watch out when removing and refitting the new cylinder? Is it easy to remove once brakes are bled? It looks to be two bolts then pull them apart, is it more complicated than this?
Thanks for any help anyone can give.
1989 Golf GTI 8v Tornado Red <br />2004 Bora Highline TDI 180bhp Shadow Blue
Offline Mr Blue
Re: Fitting 16v master cylinder
« Reply #1 on: 04 February 2007, 21:06 »
Offline mattp1983
  • Keep it VAG :)
« Reply #2 on: 04 February 2007, 21:48 »
Cheers fella I didn't see that, thanks.
Offline davidsmith
« Reply #3 on: 05 February 2007, 19:01 »
Hi
I have just replaced the master cylinder on an 8v, it just bolts to th efront of the servo - you can just get a 13mm socket on the nuts.
IS the 16v master cylinder actually any different to the 8v, I think they are the same but with an 8v there is a blanking fitting in one of the outlets - good luck anyway  David
Offline mattp1983
  • Keep it VAG :)
« Reply #4 on: 05 February 2007, 22:13 »
Yeah the 16v one is bigger, think internally, its capable of higher pressure, probably due to the 16v having larger discs and pads? which I am upgrading t o as well  :smiley:
