Author Topic: help wanted mfa and relays  (Read 1042 times)
Offline brummydubber
« on: 04 February 2007, 12:20 »
i changed the clutch all was fine before
now fuel ingecters wont switch off
broke knock sensor changed that
cleaned all conections and plugs changed fual relay
but still fills cylinders with fuel when ignition is on
pulled out the 32 relay to stop pump
any idea wot this is could it be the problem help
and mfa dont work any ideas clocks are fine
no rev counter working
Offline takethefifth
Re: help wanted mfa and relays
« Reply #1 on: 04 February 2007, 12:46 »
I am afraid it sounds like an earth strap hasn't gone back on properly when its been reassembled and then ECU has fried itself.  The constant fuel pumping is a good sign of a knackered ECU. Ebay or a scrappy for a replacement.
Offline Uruk Hai
« Reply #2 on: 04 February 2007, 13:07 »
It mite be worth seeing if you can borrow a "good" ECU off someone to try on yours and then you'll be sure before you spend out on another ECU !
Offline monzablue16v
« Reply #3 on: 04 February 2007, 13:28 »
Replace the erath first though or you'll end up frying that one as well :)
« Reply #4 on: 04 February 2007, 15:18 »
is there anyway i can tell from looking at the printed board inside
« Reply #5 on: 05 February 2007, 10:40 »
Its almost definitly blown, clean up all the battery/starter/alternator leads especially the gearbox earth with sandpaper till they're proper shiny and refit.
If it still floods the engine, go and buy a new ECU!
