Author Topic: Rough start up  (Read 1990 times)
Offline gil157
Rough start up
« on: 23 January 2004, 13:41 »
Can anyone help? My Mk11 GTi ('92) is driving me nuts, on start up it runs really lumpy and if it stalls in the first 30secs it just refuses to start as if it has been totally flooded. After the first minute of driving she runs smoothly and is a dream except.....when you take your foot off the throttle it lurches badly and does the same if coasting and not applying much throttle pressure, where do i start? Thanks.
turbo
Re:Rough start up
« Reply #1 on: 23 January 2004, 22:26 »
check the normal stuff plugs dizzy cap and rotor arm,
check the earth connections on the engine also check your high and low tention wires on your ignition coil...
the damp plays havoc with the ignition system in the winter..... if theses are all fine then it could be anything..... i would also try some injector cleaner like redex or slick 50 fuel system treatment as you may have blocked leaking injectors this will remove the carbon out of them and return spray pattens to normal..
« Last Edit: 23 January 2004, 22:31 by vwsystems »
Offline gil157
Re:Rough start up
« Reply #2 on: 24 January 2004, 09:20 »
Thanks for advice, have checked all ignition system and put injector cleaner through still got a problem somewhere, let you know when I find it.
Veedubgt18v
Re:Rough start up
« Reply #3 on: 24 January 2004, 10:18 »
check all vacuum lines and breather hoses etc, make sure you got no broken/frayed/loose wires on any of the sensor for the ecu
Offline gil157
Re:Rough start up
« Reply #4 on: 26 January 2004, 12:31 »
 Thanks for help found cold start sensor has failed and corroded connections on ecu, cleaned up and coated in wd40 much better starting now.
