Author Topic: Req info on wheel measurements  (Read 798 times)
Offline shaft69
« on: 02 February 2007, 23:17 »
Im looking to buy new wheels, So what i've found are revolution wheels are 8jx15" either ET10 or ET0. Need wheels to fill G60 arches. At moment using ats cups 7jx15 ET 20 and filling arches. Arches have been pro cut on front and rolled on rear so all thats ok. Which ET size would be best to fill arches you think? Kevin
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Agreeable Slick
  • Unit
Re: Req info on wheel measurements
« Reply #1 on: 03 February 2007, 01:28 »
20 something should do fine.
Offline shaft69
« Reply #2 on: 03 February 2007, 23:23 »
Sorry slick ment my cups are NOT filling arches :cry: There is a good inch from wheel to arch, Also at rear about 10cm between wheel and arch but not yet fitted G60 arches on rear so will be even more room to play with.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline richard s
« Reply #3 on: 04 February 2007, 22:01 »
i think i have corrado rims on mine and am sure they are et 35
« Reply #4 on: 05 February 2007, 10:59 »
ET10 should fill the arches nicely I think, but you'll need archwork but since you've had this done it should be fine.
I have ET28 7j wheels on mine with 16mm spacers on the rears which I think works out to ET12, and it rubs at the rear over large bumps and with 2 passengers in the back.
