Author Topic: Engine wiring looms  (Read 736 times)
Offline mtaylor55
Engine wiring looms
« on: 02 February 2007, 22:09 »
Hi,
I'm putting a 2.0 16v ABF engine into my MK2 Scirocco. I didn't get a loom with the engine. Is a MK3 8v GTI the same loom? If not, can it be easily adapted.
16v looms seem to be thin on the ground.
Thanks
Mark
Re: Engine wiring looms
« Reply #1 on: 05 February 2007, 10:12 »
nope the engine managment is totally different for the 8v, you might be better off converting to 1.8 16v K-Jet managment, quite a bit cheaper and much more simple. You'll need:
ISV + loom + ISV controller
ECU + loom
Injectors (buy new brass mercedes ones from ebay, £50)
WUR
Inlet manifold + 5th injector
Fuel lines
Metering head
