Author Topic: MFA stuck...  (Read 2270 times)
Offline [han]
  • Graphic Designer for Haribo
MFA stuck...
« on: 02 February 2007, 12:09 »
finally got my MFA working,
MPH work, but the oil pressure says --- and the temp for the last option (not sure what it is says -40degrees.
any idea how to set this so it works? or am i stuck?
regards.
Re: MFA stuck...
« Reply #1 on: 02 February 2007, 13:14 »
oil temp will stay at --- until the engine warms over 50degrees, so check that.  If it still reads -- earth the temp sender wire to the head/block (small spade terminal, black/green wire) it should shoot up to 150degs or something.
As for the outside temp sender, make sure the sender hasn't fallen off, on a MK1its stuck inside the front bumper :)
Offline ian007miles
Re: MFA stuck...
« Reply #2 on: 08 February 2007, 17:33 »
hi there try this .This same 'hiccup' also often occurs if the battery is flattened or disconnected. Instead of displaying the usual range of trip information, the tiny screen either shows just some horizontal lines at the bottom or it goes completely blank! In the worst case this will mean a replacement unit but there is also a quick fix worth trying (you will need a happy helper for this job):
ALWAYS TAKE CARE WHEN DEALING WITH BATTERIES/ELECTRICS
*Disconnect the battery.
*Hold down the MFA button.
*Reconnect the battery.
*While still holding down the MFA button, turn on the ignition, release the button and *turn off the ignition.
*Hold down the MFA button again, turn on the ignition and release the button.
You should now have a correctly working display. It has been known for the display to jump into life halfway through the process. If this happens, you can congratulate yourself and stop right there, for it has been known for the computer to 'hiccup' again if the process is continued after it comes back to life!
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline [han]
Re: MFA stuck...
« Reply #3 on: 08 February 2007, 21:41 »
its also not keeping time either  :cry: hmmmm.....
