Author Topic: Weird Idle Problems  (Read 937 times)
Offline WhiteMk2Gti
Weird Idle Problems
« on: 31 January 2007, 21:41 »
Had the tappets and cam belt changed, and since then the idle is all "weird"
It will fast idle (1,200rpm) then settle down, but can go back to that at the next stop.
Now its taken to jumping up to 3,000rpm till i switch off.
On re-start it makes a "squeal" noise and wont go. switch off, switch on, and its fine.
i have been told its the "ideal control valve", whats that, where is it and how much is a new one?
Mk2 Golf 1.8Gti
You know you want to, you dont realise it yet!
Offline systemseiko
Re: Weird Idle Problems
« Reply #1 on: 31 January 2007, 22:54 »
Sounds like either incorrect timing setup,  faulty hall sender on the dizzie or the link as follows,  applicable to the 16V's and 8V's  http://www.golfgtiforum.co.uk/index.php?topic=22031.0 please correct me if i'm wrong,  try teh link attached good info from the lads on site http://www.golfgtiforum.co.uk/index.php?topic=48060.0
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
