Golf mk5
What's the "set" button for next to the shift lever?
Topic: What's the "set" button for next to the shift lever? (Read 3215 times)
TeddyKGB
Guest
31 January 2007, 20:31 »
Until I get my English manual - what does this button do and how do I use it?
Phil mcavity
Guest
Re: What's the "set" button for next to the shift lever?
31 January 2007, 20:46 »
tyre pressure monitor, after you check your tyre pressures , press and hold button and it memories your tyre pressure settings, so if you have a slow it tells you on your dashboard computer
TeddyKGB
Guest
31 January 2007, 20:48 »
Cool - thanks
dalgleish00
GTI forum regular
01 February 2007, 13:19 »
anyone experienced this actually doing anything??!!
05 Pearl Black GTI DSG - most extras
Phil mcavity
Guest
01 February 2007, 15:01 »
yes, i did, had a nail in the centre of the tyre and yes it works, tells you in your highline computer you have low pressure and illustrates which one too
TeddyKGB
Guest
01 February 2007, 15:42 »
Hmmm.. what about us with the "peasantline" computer?
Pintman
Reply #6 on:
01 February 2007, 17:04 »
Does anyone know what pressure difference the tyre has to be to 'make' the icon illuminate?.
I also have the 'peasantline' computer. Checked the other day and tyre pressure was 29 after I knowingly set the indicator to 35psi!.
Couple of months ago, got into the car not knowing the tyre was completely flat and drove down the road. It was only the car pulling to oneside that I knew one was flat, but no illuminated icon
wantmygti
Reply #7 on:
01 February 2007, 17:10 »
Well that sounds busted then!
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Golf mk5
