Author Topic: VagCom Codes - Advice  (Read 1282 times)
Offline Desperado2
« on: 31 January 2007, 09:28 »
Hi there,
I've got a MK4 GTI 1.8T on a 2001 plate and every 3 months or so the engine warning light comes on. It happened yesterday so I got my VagCom cable out and laptop and took a look to see what it was, it's the same as previously had:
Address 01: Engine
   Controller: 06A 906 032 DR
   Component: 1.8L R4/5VT         0002
   Coding: 11500
   Shop #: WSC 00028
3 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
            P1297 - 35-00 - Connection turbocharger - throttle valve pressure hose
            P1137 - 35-00 - Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
            P0411 - 35-10 - Sec.Air Inj.Sys. Incorrect Flow Detected - Intermittent
Readiness: 0000 0000
Now to me this sounds like a loose hose or something but would anyone know what these are the symptoms for? and any advice on how to fix it without too many pennies being spent.
Thanks
Ed
Say bye bye
Re: VagCom Codes - Advice
« Reply #1 on: 02 February 2007, 20:16 »
