Author Topic: spark plugs leaking oil  (Read 1149 times)
Offline kr1s77
« on: 30 January 2007, 16:53 »
hi all, i have a 2.0 8v and have a oil leak problem, the oil is leaking out from the spark plugs. i have done the rocker cover gasket. it has had an effect on the porformance, as the car is not responsive as it used to be. have a look at the pic.
http://i86.photobucket.com/albums/k89/kr1s77/Oil.jpg
does anyone know what this is called, it's what the oil breather pipe goes into at the bottom of the engine
http://i86.photobucket.com/albums/k89/kr1s77/whatsthis.jpg
thanks
ASV 1.9 TDI 110
Offline monkeyalan
Re: spark plugs leaking oil
« Reply #1 on: 30 January 2007, 17:01 »
that pipe is the crankcase breather pipe i think.
If you have oil getting into the cylinders it may be being forced in due to excess pressure in the crank case.
take that pipe off and the other part of it that goes to the throttle body and make sure they're not blocked.
i'm sure someone else will be along with some more suggestions soon.  :smiley:
Offline kr1s77
« Reply #2 on: 30 January 2007, 17:23 »
i have already changed the two pipes that make that up.
thanks
ASV 1.9 TDI 110
