Author Topic: which seals??  (Read 1229 times)
Offline rowlers
  • I'm back - MK7 GTI
which seals??
« on: 29 January 2007, 22:05 »
I'm fitting merc injectors at the w/e but not sure which seals and stuff I needs
I'm planning on ordering number 16 *4.
Last time I pulled the std. injectors none of the other "bits" were in the end of them - just the injectors with the big rubber ring around the top (16)
Any one know if thats all I need?
Offline Lewy
Re: which seals??
« Reply #1 on: 29 January 2007, 22:38 »
Why?
Re: which seals??
« Reply #2 on: 30 January 2007, 17:00 »
You need from VW:
035 133 557 - injector insert seal - 0.87 x4
and from GSF:
18720 SEAL-RING-INJECTOR  G2 16V 2/86 >10/91  0.60 x4
Or from VW if you don't want GSF ones:
035 133 557 A - injector seal - 1.88+VATx4
You use merc injectors because they are cheaper, and made of brass so don't rust.  Theres a guy selling em for £50 a set on ebay ATM :)
« Last Edit: 30 January 2007, 17:02 by rubjonny »
Offline rowlers
Re: which seals??
« Reply #3 on: 30 January 2007, 20:39 »
cheers jonny! :wink:
How come you need 2 sets of seals, also how come I don't need the big seal around the top 034 133 557 e?
cheers fella!
Offline rowlers
Re: which seals??
« Reply #4 on: 31 January 2007, 21:43 »
can you just confirm the part numbers please rubjonny.
ta mate
Re: which seals??
« Reply #5 on: 31 January 2007, 22:18 »
Sorry it is 034 133 557 e you need, the one I listed is for the 16v injector 'top hat' seal, which isn't present on the brass merc injectors :)
Offline rowlers
Re: which seals??
« Reply #6 on: 01 February 2007, 18:59 »
thought I'd caught you out :grin: :grin: :grin: :grin:
cheers fella
get them ordered 2moro!
