Author Topic: VW 1.4 engine cutting out when revs drop......  (Read 1203 times)
Offline gtireece
« on: 29 January 2007, 20:48 »
Ive got a second car, a 1.4 polo L on a P plate. Recently it seems to developed a fault that is random, will not do it for days but then can do it everytime you drop revs. Usually coming to a set of lights and dipping the clutch the revs will drop as usual but wont stop and bounce up when it gets to like 750rpm, instead it just drops to 0 and engine cuts out.
BUT!! if you blip the accelerator as u dip the clutch it doesn't cut out...any ideas I'm stumped? :undecided:
Acceleration with no turbo lag
Offline adyh
Re: VW 1.4 engine cutting out when revs drop......
« Reply #1 on: 02 February 2007, 10:46 »
Check the engine breather pipes for holes,.
Offline tom26
  • team chumpy.
« Reply #2 on: 02 February 2007, 16:06 »
My mk2 16v has had this problem before. John mitchell of JMR racing explained to me that sometimes when braking, the engine can rock forward/back exsposing small air leaks that are past the airflow meter so not adjusted for, letting in too much air thus stalling the engine.
« Last Edit: 02 February 2007, 16:08 by tom26 »
Offline Vee_Dub_Fraser
« Reply #3 on: 02 February 2007, 20:01 »
might need to replace the filter element in your airbox, this happened to my fiesta and it fixed the problem.. hope that helps!
