Author Topic: suspension trouble  (Read 1917 times)
sacvwgolf
suspension trouble
« on: 27 January 2007, 16:53 »
when i put new shocks + springs on the car i had trouble tighten the bolt at the top.
I bought a deep offset ratchet thing but could not get it deep enough to do the nut up fully.
tool used:
Any advice on which tools to use?
Also there was a bit of a gap at the top see picture. is this normal?
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
Re: suspension trouble
« Reply #1 on: 27 January 2007, 17:31 »
bloody hell
my suspension must be knackered
mine sticks up about half a inch
sacvwgolf
« Reply #2 on: 27 January 2007, 17:50 »
yeah mines about the same. i don't know why though!!!
Offline Mew
« Reply #3 on: 27 January 2007, 18:08 »
Buy a socket (23mm or whatever the nut is) from halfords and then grind off two flats on the outside so you can get a conventional spanner on it. Then just stick your allen key down the middle and tighten up! Well that's how i did it anyway
sacvwgolf
« Reply #4 on: 27 January 2007, 18:19 »
that sounds like it could work thanks  :smiley:
is the gap normal?
Offline Mew
« Reply #5 on: 27 January 2007, 18:33 »
Erm, i've got a gap but would say it is only around 5mm or so, maybe a bit more? You may well find that when done up properly that the gap is reduced. A gap is normal though, just not sure about 20mm! Sorry
Offline filthy
« Reply #6 on: 27 January 2007, 18:38 »
easiest way is to use a 22mm ring spanner, with a good offset....
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
sacvwgolf
« Reply #7 on: 27 January 2007, 18:40 »
is that what i got? in the picture
Offline mattp1983
  • Keep it VAG :)
« Reply #8 on: 28 January 2007, 13:09 »
well that depends... if it fits then yeah, if it doesn't then no.... try and see, you definately need the allen key as well though.
1989 Golf GTI 8v Tornado Red <br />2004 Bora Highline TDI 180bhp Shadow Blue
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #9 on: 28 January 2007, 13:37 »
The gap is normal although it depends on how much the gap is as to the condition of the strut mount. My old ones had a gap of about 15-20mm. With the car jacked up though, this gap disapeared, although the strut could be moved up and down with ease, indicating the mounts were shot. The new ones have a gap of 5mm or slightly less.
I have heard that G60 mounts are better, (last longer) although they are a different part number, they still fit. (Needs verification!)
