Author Topic: mk2 golf suspension  (Read 1866 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
mk2 golf suspension
« on: 27 January 2007, 15:48 »
just a question how far does the top of the strut stick out of the strut tower on the front
mines out about half a inch and my car makes a knocking sound just wondered if
its that i jacked car up and they is movement in the strut rubber might be perished
and how easy is it to change the rubbers in the top i think i have some poly bushes kicking about
Offline RoodGtiLooker
  • Bis macht Tod uns trennen
Re: mk2 golf suspension
« Reply #1 on: 30 January 2007, 09:44 »
yer im also gettin the same any help would be great??
working at last for compass
Offline Coog
« Reply #2 on: 30 January 2007, 11:06 »
Theres a post somewhere on here about this mate, quite recent too (have a search).
IIRC mine had no or a very very little gap between the top plate and the strut tower. I used new G60 top mounts (from GSF).They're easy to change, just drop the shock out and the mount usually sits on top, replace and hey presto. The top nut takes some ingenuity to remove/tighten however.  :tongue:
MK2 Golf GTi 16v
Offline tom26
  • team chumpy.
« Reply #3 on: 30 January 2007, 15:51 »
G60 top mounts are much better that the standard ones. when i recentley had coilovers fitted, ...joe recommended i upgrade the top mounts too. cost about £30 for the pair!
Offline Mr Blue
« Reply #4 on: 04 February 2007, 01:16 »
rob they shouldnt stick out too far.
Its probably due to your heavier engine so get uprated ones. Mine made a 'click' noise when worn.
Does this pic help?
Offline VR6_ROB
« Reply #5 on: 04 February 2007, 14:55 »
its on my gti not the vr6 sorted it now changed the mounts
but they is a knocking when i turn right dunno what it is nothing seems loose
thought changing the shock mounts could of solved this but i guess not
more of a click then a knock though
Offline Golf8vGti
« Reply #6 on: 04 February 2007, 16:24 »
CV joint??
