Author Topic: New clocks/Changing mileage  (Read 2825 times)
Offline G60Dan
  • 20VT baby!
« on: 27 January 2007, 15:13 »
Need a bit of help, I have a new set of 16v clocks I want to put in my mk2 to replace my 8v ones. I need to change the change mileage to be the same as the old clocks. Anyone able to pm my a guide? I have the clocks in bits at the moment, but don't want to break them.
Dan
Breaker
Re: New clocks/Changing mileage
« Reply #1 on: 27 January 2007, 16:01 »
if you remove just the clock part then you can change that over and keep the new mfa/rev counter etc.
this helps if the speedo is a 140 instead of a 120 and you keep the miles as well.
is you undo the screws behind the speedo part it will lift out sideways with a bit of encouragement
you might have to undo some screws for the other half.
i dont have a picture but search for bently manual. theres probaly something good in there!
Offline systemseiko
« Reply #2 on: 27 January 2007, 19:51 »
If you want to wind the mileage back you can do this with a pencil with a rubber on top,  use the rubber to push individual digits down or up,  not that i am a mileage chopper or anything,  ensure all individual digits line up,  pretty easy done,  but i would go for Breakers option if you have complete unit dismantled.
 :undecided: :undecided: :undecided: :undecided: :undecided: :undecided: :undecided: :undecided: :undecided:
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
Offline G60Dan
  • 20VT baby!
« Reply #3 on: 27 January 2007, 20:25 »
cheers fellas
I'll give the pencil rubber thing a go.  :cool:
Offline G60Dan
  • 20VT baby!
« Reply #4 on: 27 January 2007, 21:28 »
na doesnt seem to be working.
Does the needle pull off?
Breaker
« Reply #5 on: 27 January 2007, 22:22 »
yes but be carefull they dont go back on to well.
my rev counter is out by about 200 now  :sad:
Offline G60Dan
  • 20VT baby!
« Reply #6 on: 27 January 2007, 22:34 »
I don't need to do the rev counter, just the speedo to do the miles.
The needle really doesn't want to come off, and the numbers wont budge  :sad:
Breaker
« Reply #7 on: 27 January 2007, 22:37 »
try and unclip one of the sides where the red screw gear is (i think)
it will pull forwards and you can change the numbers
Offline Mart8V
  • I really should know better by now.....
« Reply #8 on: 28 January 2007, 11:24 »
If you are going to take the back off the clocks make sure you warm the circuit system first.  They can be a bit brittle, so 2 mins with a hair dryer may be time well spent.
Offline G60Dan
  • 20VT baby!
« Reply #9 on: 28 January 2007, 18:14 »
All sorted now. Flicked the little red wheel off, and wound it back. Thanks for your hlp lads.
