Author Topic: has anyone got the slotted nut tool in sussex ?  (Read 1337 times)
Offline smckeown
« on: 27 January 2007, 13:42 »
cant get hold of one today, and would like to borrow one.  Would appreciate any owners in sussex lending me one.
cheers
sean
Offline rowlers
  • I'm back - MK7 GTI
Re: has anyone got the slotted nut tool in sussex ?
« Reply #1 on: 27 January 2007, 14:12 »
you don't stricktly need it - ust makes the job a little less fiddly...
as long as you take the tension of the springs with your spring compressors, you will be able to take the nut off with some long nose pliers or simliar!
give it a go! :wink:
Offline smckeown
« Reply #2 on: 27 January 2007, 15:02 »
I want to be able to do it back up tight :)
Offline rowlers
« Reply #3 on: 27 January 2007, 16:11 »
the same goes...
tension spring back up, spin the nut down the thread, tighten up with thin nose pliers/molegrips.
once the full tension of the springs has been released that nut is going nowhere!
I have the tool, but it is not 100% great, takes effort/patience to keep it on top of the nut!
Offline smckeown
« Reply #4 on: 27 January 2007, 19:50 »
i'm sorted now thanks lads.  I ended up making my own in the end.  Even though in too soft an ali it made the fitting a million times quicker.  I'll still buy a proper one to get it really tight.  I actually ordered one from amazon this week but had hassle with my card, and expected a locat motor factors to have them in stock..i was wrong :)
Offline Mart8V
  • I really should know better by now.....
« Reply #5 on: 28 January 2007, 11:22 »
You can also use a mallet and punch if you are careful- have managed that successfully.  Lots off little taps will get it there eventually.
Offline VWDino
  • MkII 1.6 Driver. GTi cam, K&N .....
« Reply #6 on: 28 January 2007, 21:58 »
Just had to replace both dampers on my car, managed to make a tool out of a length of ally pipe. Worked a treat
sacvwgolf
« Reply #7 on: 28 January 2007, 21:59 »
i used a pair of long nosed pliers
