Author Topic: Noisy 16v Injectors  (Read 2069 times)
Offline Gambit
Noisy 16v Injectors
« on: 22 January 2004, 09:05 »
anybody else get this?
on cold mornings mine chatters away to itself for the guts of an hour before eventually quietening down
anyway of quietening them down from the word go?
Cheers,
Craig
golfvr6
Re:Noisy 16v Injectors
« Reply #1 on: 22 January 2004, 11:21 »
How can the injectors be noisey?
Offline Gambit
« Reply #2 on: 22 January 2004, 11:29 »
its coming from the area so that all i could think off!
ive been told it could be belt noise
golfvr6
« Reply #3 on: 22 January 2004, 11:36 »
I don't think they will be noisey as they are not the electronic type with solenoids, well i've never seen noisey injectors on a k-jet.
What sort of noise?
Offline Gambit
« Reply #4 on: 22 January 2004, 12:14 »
its not a metallic noise, its a more ch ch ch noise coming from the front left corner
around the airbox and alternator
Offline mk1
« Reply #5 on: 22 January 2004, 22:03 »
Belt noise  ???.
Take the drive belts off and run for a short time to check.
Steve.
Offline modulater
« Reply #6 on: 22 January 2004, 22:09 »
As said it wont be injectors.
run the engine and using a long screwdriver  put the tip on the rocker cover on the side of the noise then put your ear on the handle end and you'll hear it more clearly.
Also try the above on the alternator to listen for bearing wear.
MK1's idea is also good darts.
