Author Topic: how easy  (Read 1564 times)
Offline jasonpi
how easy
« on: 22 January 2004, 08:52 »
would it be to drop in a vr6 lump in a mk2????
Offline Dizzie
  • Make friends with your fast
Re:how easy
« Reply #1 on: 22 January 2004, 11:54 »
easy to bolt it in. harder to wire it up...
?3995 from Dubsport all in
Offline jasonpi
Re:how easy
« Reply #2 on: 22 January 2004, 12:47 »
i can get a recon enihne for around 900 notes with wiringloom ecu etc etc...cant justify an extra 3000...how hard in all honesty is it to wire up???
Offline Gambit
Re:how easy
« Reply #3 on: 22 January 2004, 13:38 »
yours is a wiring nightmare as you have the early spec loom (hazard light on the dash)
if you had the late spec loom then
you want the whole VR6 front end, engine, gearbox, loom, subframe, drives shafts the heap basically
unbolt your exisitng subframe, lift chassis up, drop out subframe with engine box & and replace with new one
v.much simplified terms!!
Offline jasonpi
Re:how easy
« Reply #4 on: 22 January 2004, 14:06 »
 ??? no its ok then
