Author Topic: coolant  (Read 1453 times)
Offline yabbie
coolant
« on: 24 January 2007, 20:46 »
hi all ive got a slight problem with my golf gti mk3 2 liter it over heated one day and ever since its never held the coolant at one temp ie everyday i check it its at a diffrent level ive changed the cap and still have this problem. when it first overheated i lost all power and saw alot of smoke behind me now on that same day i think i added abit to much oil in so i do think its got anything t5o do with it overheating but it did.
the on another time it over heated i was doing a little over the speed limit  :wink: and it did the same lost all power looked behind and saw a load of smoke check the engine and no coolant whats causing my problem oh and are the pipes meant to be really hard when really hot i could even squeeze them could some thing be block. i havent had the problem over heating for about 1 week but i have this problem with the coolant thanks
Offline raylee25
Re: coolant
« Reply #1 on: 24 January 2007, 22:28 »
Get your head pressure tested, you may have small cracks in the head (cylinder). If so its a new engine mate.
Offline AudiA8Quattro
Re: coolant
« Reply #2 on: 24 January 2007, 22:43 »
Likely head gasket failure.
Offline yabbie
Re: coolant
« Reply #3 on: 25 January 2007, 09:54 »
would i not get any of the mayo stuff ? forgot to say it only done it in the higher revs range. so you think it might be a new engine  :cry: but on the plus side i hear a can fit a 2.9 into the engine bay  :smiley:
Offline yabbie
Re: coolant
« Reply #4 on: 25 January 2007, 10:08 »
just thinking about this would i not have a problem with my heating if the gasket was knackered
Offline mase
  • mk3 madness!!!
Re: coolant
« Reply #5 on: 25 January 2007, 14:28 »
youd also have a loss in performance, it would constantly over heat, and youd possibly get some blue smoke coming from the exhaust. wat colour was this smoke when u noticed it the times is overheated?
you could just have a leak somewhere, which is resulting in coolant loss...
a head pressure check will tell u for defo weather the headgasket is gone, and even if it has, you might just get away with changing it.... if it has caused a crack in the head, then getting it skimmed might fix that, or... in a worse case senario youll need a new head, not a whole engine.
Quote from: Slick#13
I still see there is a distinct lack of b!tch tit getting outage.
...word
Offline yabbie
Re: coolant
« Reply #6 on: 25 January 2007, 22:38 »
umm it was white like on a cold morning but it just hang in the air only happened twice. and its bit about one week since its happened and i dont have any mayo stuff thick i will get it checked any ways where about in the coolant thermostat in the 16v abf model ? is it near then water pump ?
