Golf mk2
display for mpg
Topic: display for mpg (Read 1505 times)
Stu M
Just got here
display for mpg
22 January 2004, 01:09 »
hey guys
with my new mk2 gti i notice it has an electronic display that u can cycle through temp mpg mph etc wiht the right stick. but the mph and mpg dont have nothing
does anyone know if it should display something and if so what could be wrong with it
thanks stu
Veedubgt18v
Guest
Re:display for mpg
22 January 2004, 01:17 »
for the mpg the sensor is a vacuum tube (thin see thru thing) on the extreme right of the throttle body check it is plugged in other than that pull the second fuse out from the right and it will reset the mfa, worth a try!
Dizzie
Forum addict
Make friends with your fast
Re:display for mpg
22 January 2004, 11:54 »
I recently found that out when I couldn't reconnect the dials end of the tubing cos it was snagged on something so I disconnected the other end to stop the sucking noise that was annoying
Mk2 Golf GTi restoration -
https://youtu.be/s-Jj5bABxM8
Stu M
Just got here
Re:display for mpg
22 January 2004, 15:19 »
cheers dude ill give that a go just now, just bought some infinity 6,9's to so off to wire that up
stuart
Golf mk2
display for mpg
