Author Topic: Suspension kits ..........  (Read 1266 times)
Offline bulk66
  • Im broke an it aint a joke!!!!
« on: 23 January 2007, 21:58 »
Hi all I'm after a suspension kit for my 93 VR6 Ive got a maximum of £250 to spend any one got any suggestions oh and i can only go 30mm cheers........... :smiley:
Offline patch900
Re: Suspension kits ..........
« Reply #1 on: 24 January 2007, 09:34 »
Bulk, there are some spax here for £269:
http://www.motorsportworld.co.uk/frame-detail.asp?PAGE=/manranges.asp
I know its more than 250, another thing is they drop 35mm !
Virtually everything I know about the workings of the internal combustion engine can be written on the back of a small stamp with a large marker
Offline zorro
« Reply #2 on: 24 January 2007, 11:39 »
Got a G-Max one on mine, £220, drop of 35mm. Decent ride too.
Think i 'googled' G-Max and then shopped around...
Chris
2014 GTI PP
Offline Hypermonkey
  • Only users lose drugs!
« Reply #3 on: 24 January 2007, 13:09 »
Just had a Wietec kit fitted to mine. Cost roughly £250 and is far superior to many more expensive ones. I've had G-max, Eibach, Koni, spax etc and these are by far the best.
If you are local to Reading then Storm Developements can get them in and the fitting is very reasonable.....just remember to get new top mounts and top mount bearings and possibly rear bump stops...may as well as they are all accessable and worth the extra £50 :smiley:
I'm not nocking the other brands, it's just I do track days and driver days in mine and these Wietec ones are fantastic :smiley:
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 24 January 2007, 13:12 »
Boge do a good suspension kit for about £220 and drop's by 30mm....I have fitted boge shocker's to mine and they are much better than the original's.If you check through previous post's about shocker's boge get many mention's of being the quality (allthough most people say you should get them with eibach spring's like I have)..I got my shock's and eibach spring's for about £260 by shopping around..Just make sure when pricing etc you check they are for the earlier shock's and spring's as these changed on 94 to a larger diameter spring
Offline bulk66
« Reply #5 on: 24 January 2007, 16:09 »
Cheers for that every one.... :grin:
