Author Topic: play in gears?  (Read 1069 times)
sacvwgolf
play in gears?
« on: 23 January 2007, 12:41 »
i was just wondering if there should be play in the gear stick. when you put in to a gear, you can move the gear stick side to side quite a lot. is this normal or should i change the gear ball thing?
Offline Gambit
Re: play in gears?
« Reply #1 on: 23 January 2007, 13:05 »
yes, get a gear linkage repair kit, along with a replacement relay shaft ball - i think someone on here does the relay shaft balls
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: play in gears?
« Reply #2 on: 23 January 2007, 14:15 »
gambit, does the relay shaft ball fit the 1.3 primitive linkage? and scott, you may find that the palys in teh actual box, it is with mine, you can see the entire selector rod where it enters the box is loose  :undecided:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline mk2mark
Re: play in gears?
« Reply #3 on: 23 January 2007, 15:20 »
Wonder who that could be? :laugh: Follow the link in the link in my sig. simple!
sacvwgolf
Re: play in gears?
« Reply #4 on: 23 January 2007, 17:52 »
i not sure that there is any play in the box. i labeled the picture showing where the play is aswell as the gear stick.
if i replace the gear lever ball would that help?
« Last Edit: 23 January 2007, 19:56 by sacvwgolf »
Re: play in gears?
« Reply #5 on: 23 January 2007, 22:47 »
where you put no play here, get someone to actually wiggle the gearknob when is in, and check, see if is turning, i was suprised when i checked, cause it was there.. if it was up the top you would have hell of a lot of rouble changing the gears as it would be all over the place if it wasnt tight
Quote
