Author Topic: urgent help needed - re exhaust manifold  (Read 1826 times)
Offline xxdansigxx
« on: 22 January 2007, 17:58 »
Hi my manifold has a crack in it wich iv'e welded lol did a quick job and it's gone again now this it the pic of the mani:
not even my dog is sure if its right or not lol
and this is the mani on my m8t's gti 16v
now first off i know the second mani is the wrong way around please look past that...
wich one of these mani's should be the standard on a 90-91 mk2 gti 16v??
out cars are only one reg away from each other..
Did they make different ones?
also does anyone know where i can get the top one from iv'e phoned local scrappies without any luck.
thanks Dan
Offline turbodub
Re: urgent help needed - re exhaust manifold
« Reply #1 on: 22 January 2007, 18:06 »
Ermm.....the top one is an aftermarket four branch manifold.
Offline xxdansigxx
« Reply #2 on: 22 January 2007, 18:23 »
umm it's only mild steel though :S
Offline Uruk Hai
« Reply #3 on: 22 January 2007, 18:57 »
Your probably better off putting the standard one on as aftermarket four branch manifolds can crack or snap if a vibratech type (solid) engine mount isn't fitted due to the pressure put on the manifold by the movement of the engine.
Offline xxdansigxx
« Reply #4 on: 22 January 2007, 19:30 »
umm iv'e got the uprated engine mounts fitted the engine doesnt move at all lol...
oh well if i cant find another one ill have to repair it again :S
Offline Dub-77
  • Dub again MK1 Golf Project
« Reply #5 on: 22 January 2007, 20:18 »
Do you still need solid mounts even with that flexi joint at the bottom of the downpipe??
Darren
Show me a man with a tattoo and i'll show you a man with an interesting past :wink:
Offline xxdansigxx
« Reply #6 on: 23 January 2007, 06:47 »
not really as you can see from the first pic i have no flexi joint.......
Offline NewStu
« Reply #7 on: 23 January 2007, 11:23 »
A new Stainless Steel 4 Branch manifold will cost anywhere from £250 to £350 and can be bought from loads a places.
« Reply #8 on: 24 January 2007, 11:26 »
Thats still an aftermarket 4 branch, just not stanless. No 16vs got em from the factory, the second pic is what a factory 16v manifold & downpipe look like :)
If you have a solid metal front engine mount, it shouldn't crack, unless its been made out of cheap metal
Offline Uruk Hai
« Reply #9 on: 24 January 2007, 18:35 »
I've known a lot cars with that type of manifold and some of them crack due to the amount of vibration that comes from the engine regardless of the type of engine mount.
