Author Topic: mk3 gearbox green cap  (Read 1915 times)
Offline 8vlover
« on: 21 January 2007, 21:28 »
hi everybody. this is my first post on this site. hopefully somebody can help me.
what is the green plastic bit on top of the gearbox on my mk3 2.0 8v gti.
and most importantly is it supposed to be sealed
Offline boneybradley
  • Back in a Mk3...
Re: mk3 gearbox green cap
« Reply #1 on: 21 January 2007, 22:55 »
You can take that out to see the timing mark's on the flywheel (these golf's have the flywheel on the outside of the clutch).......it should be screwed in but i can't see the point of fully sealing it as I dosen't hold oil etc
Offline 8vlover
« Reply #2 on: 22 January 2007, 22:02 »
thanks very much. had concern cause mine had nothing in the middle just a hole
Offline monkeyalan
« Reply #3 on: 22 January 2007, 22:38 »
they're about £2 from VW. Mine was "misplaced" after a service.
best fill it in.
Imagine if you droped a screw or summat in there!  :sick:
Offline Saffa
« Reply #4 on: 23 January 2007, 21:18 »
The hole in the middle is where you would fit a diagnostic machine timing sender used by vw dealers. as said above it can be removed so you can see the TDC marks. It is not an important part really.
