Author Topic: knocking noise vr6  (Read 1557 times)
Offline jparry
knocking noise vr6
« on: 21 January 2004, 19:18 »
just bought a 95 vr6 and covered about 500miles, and there is now an awful knocking noise could this be the main water pump? are these prone to going.
Car has covered 140K.
I would like to remove the belt for the water pump and quickly check that the noise goes how do you remove the belt easily?
thanks
Offline jparry
Re:knocking noise vr6
« Reply #1 on: 21 January 2004, 20:46 »
the noise is from the water pump. After the belt was removed the pump muved about 10mm up and down so the bearing must have collapsed.
