Author Topic: Head Gasket  (Read 1559 times)
Offline Kamaya
Head Gasket
« on: 17 January 2007, 09:44 »
After several months of pure trouble free motoring, my car has developed an 'oil feature' in the engine bay. Looks like the head gasket has gone :rolleyes:
Only concern for me is, the chap that I bought the car off a few months ago had said that the head gasket hadn't long been done?
Assuming he wasn't lying through his teeth, any reason why it would go within 6 months of it been done?
"You are only young once, but you can stay immature indefinitely"
Offline SiGainey
Re: Head Gasket
« Reply #1 on: 17 January 2007, 09:52 »
Head might not have been skimmed :(
Dragon Green 97 Mk3 VR6 :)
Re: Head Gasket
« Reply #2 on: 17 January 2007, 12:20 »
where is the oil coming from?
Offline Kamaya
Re: Head Gasket
« Reply #3 on: 18 January 2007, 08:40 »
It's coming from the right hand side of the block, roughly where the head gasket is. Plus i'm losing oil & water. It's not emulsifying at the moment, probably because I haven't driven it since I noticed it.
Re: Head Gasket
« Reply #4 on: 18 January 2007, 12:15 »
could just be the rocker cover gasket leaking, and coolant leaks from the plastic flanges on the front/side of the head ;)
Offline Kamaya
Re: Head Gasket
« Reply #5 on: 19 January 2007, 08:07 »
Not sure now then. Got it booked in for the weekend now. Cheers for the help.
Offline Kamaya
Re: Head Gasket
« Reply #6 on: 22 January 2007, 11:51 »
Well car is now in the garage. Mechanic doesn't think it's the head gasket, but I'll find out about 2ish.
Offline Kamaya
Re: Head Gasket
« Reply #7 on: 23 January 2007, 11:25 »
Well i've got the car back. Apparently all it needed was a new oil switch. Leak has stopped, and mechanic said it doesn't appear to be losing water anymore. Odd.
Ah well, all sorted for under £25 so can't go wrong. Will keep an eye on the water levels over next few days.... not entirely convinced it's all over yet....
Re: Head Gasket
« Reply #8 on: 23 January 2007, 11:41 »
check out the plastic flanges on the front & side of the block, most common place for an old VW to leak :)
Offline Kamaya
Re: Head Gasket
« Reply #9 on: 23 January 2007, 11:46 »
Will do. Thanks for the help  :smiley:
