Author Topic: certificate of installation of immobiliser lost  (Read 9634 times)
Offline Barnzyuk
Re: certificate of installation of immobiliser lost
« Reply #10 on: 18 June 2007, 11:48 »
thacham basically denotes a good immobiliser. if an imobiliser complys with guidelines set by thacham it will become thacham approved, which basically tells the insurance company that the imobiliser you have isnt a load of old crap. so immobilisers from any manufacturer this can apply to. alarm/immobiliser's are cat 1, whilst normal immobilisers are cat 2.
im pretty sure this is the case, correct me if im wrong :nerd:
The Steak 5.0
Offline boneybradley
  • Back in a Mk3...
« Reply #11 on: 18 June 2007, 12:44 »
Thatcham approved means it has resisted attack by the dodgy blokes from the thatcham lab........and to qualify for a cert (for insurance etc) it needs to be fitted by someone qualified by the vsib (vehicle security installation board)... That's why you need a fitting cert stamped by the installer to gain cat2.
I used to sell microscan cat2 immobiliser's from the shelf for home fitting but for these to qualify you needed to get it fitted (or tested) by an approved installer
Offline lasci
« Reply #12 on: 28 June 2007, 19:58 »
Thanks for all your help everyone, bit the bullet in the end and had another immobiliser put in, all insured now which is a relief! Def looking to change insurance companys at the next renewal, our one was most unhelpful when trying to sort out this problem!
