Author Topic: Rocker Cover sprucing up  (Read 2467 times)
Offline jaybv6
  • 03 Mk4 GTTDI PD 150
« on: 16 January 2007, 12:09 »
As I am rebuilding the top end of my engine I decided to do some detailing work on the rocker cover.  I've stripped the paint off it and it's down to the bare metal.  However I do like the look but if I fit the cover back on the way it is I know it'll be fine for a day and then rust up very quickly.  Any suggestions on what I can use to prevent the rusting.  Also if I was to paint it what type of paint should I go for?  Is it worth doing a primer and then a couple of layers of colour then laquer?  Any info would be appreciated.
Offline markmarky0
Re: Rocker Cover sprucing up
« Reply #1 on: 16 January 2007, 12:40 »
make sure u use heat resistant paint/lacker and i think kurust is good to prevent the rust, it goes on as a base layer.
I used coloured lacker on mine , did the job nicely
Offline jaybv6
« Reply #2 on: 16 January 2007, 14:15 »
Cheers for that.  Would I be able to get kurust from halfrauds?  And you used normal laquer?
sacvwgolf
« Reply #3 on: 16 January 2007, 14:39 »
hafords sell a kit which contains all you need to paint the engine/brakes but it is expensive. halfords also do their own paint which is cheep and quite good. i used it to paint my brake calipers on my moped and looks cool. With the paint you don't need lacquer as it will only melt. But be sure that the surface is cleaned be spraying. Hammerite can be used aswell i think.
Offline ...joe
« Reply #4 on: 16 January 2007, 15:29 »
just hammerite it! i've painted engines with hammerite and its been fine, they get alot hotter than rocker covers! if you're going to prime it use an etch primer on bare metal.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
sacvwgolf
« Reply #5 on: 16 January 2007, 16:17 »
is hammerite ok for brake calipers and brake drums
Offline mk2mark
« Reply #6 on: 16 January 2007, 18:20 »
Apparently so, I've never heard of anyone having problems with it. I went for BBQ paint in a can, nice understated matt finish - but I'm not sure it keeps the water out.
Offline jaybv6
« Reply #7 on: 16 January 2007, 19:18 »
What's an Etch Primer?
Offline Adam_C
  • Mk4 Golf R32
« Reply #8 on: 16 January 2007, 19:25 »
ive used hammerite on my brake calipers and i have had no flaking etc. im guessing Etch primer is a heat resistant primer you put on first befour the hammerite. thats just at a guess though
Offline Uruk Hai
« Reply #9 on: 16 January 2007, 20:09 »
Etch primer is a type of paint that etch's into the metal so it doesn't come off so easy, I don't know how heat resistant it is if at all !
