Author Topic: Petrol Gauge Problem  (Read 1182 times)
Offline patch900
« on: 14 January 2007, 16:17 »
Filled up my Mk3 at the garage to the top with petrol (the pump cut out).
Got in and drove around and the fuel gauge took ages to go up to 1/2 tank and then bloody ages to only reach 3/4 full.
Has anybody seen this before or knwo what could be wrong ?
Virtually everything I know about the workings of the internal combustion engine can be written on the back of a small stamp with a large marker
Offline robster23
  • Now a VW Fox Owner.
Re: Petrol Gauge Problem
« Reply #1 on: 14 January 2007, 17:06 »
The gauge sender is on top of the tank. Perhaps it's having a wobble. The measurement on Mk3s also seems to be gradient dependent. When driving down hill it often looks fuller than driving up hill. Maybe worth looking at the sender to see if the contacts are a little corroded, it's under the plate held on by three screws under the boot carpet I think.
hth
It's urban right? That means it must be tougher, obviously.... ;-)
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 14 January 2007, 18:33 »
You did turn the ignition off when filling up didn't you???? as mk3's have a problem of if you add fuel when on the gauge play's trick's....i had a similar problem before as I all way's left the ignition on (to stop the immobiliser and alarm coming into play) and the gauge never read correctly until she was nearly empty again and now she is ok
Offline patch900
« Reply #3 on: 14 January 2007, 19:20 »
Bradley, key was in but ignition was off. Dont know if that would do it ?
