Author Topic: Fitting Armrest  (Read 3914 times)
Offline _MaVeRiCk_
  • I fEeL tHe NeEd, ThE nEeD fOr SpEeD!!
Fitting Armrest
« on: 14 January 2007, 14:39 »
Im fitting an armrest into my mk2 gti, I have to remove the recliner wheels on the front seats but I am unable to work out how, anyone know the answer?
Offline ...joe
Re: Fitting Armrest
« Reply #1 on: 14 January 2007, 17:08 »
not sure but if its one of the ones available on ebay they suck! i bought one ages ago, it was such a bad fit i didn't bother trying to make it work and sold it straight on! shame as i like having an armrest!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Re: Fitting Armrest
« Reply #2 on: 15 January 2007, 11:56 »
you need a posidrive/philips screwdriver, but they can be BLOODY tight!  Probably easier to just swap the backrests over, if its a 3 door the handles will be on the inside which isn't to big a deal, although you'll have to reach back further to put your belt on!
« Last Edit: 15 January 2007, 11:59 by rubjonny »
Offline _MaVeRiCk_
Re: Fitting Armrest
« Reply #3 on: 16 January 2007, 01:19 »
I was told that I would have to knock it through with a screwdriver and a hammer, is that right?
Re: Fitting Armrest
« Reply #4 on: 16 January 2007, 08:05 »
Do you mean to swap the seat tilt to the other side?  I've not done it before but I guess it could be possible once you've removed the knob & trim covers...
Offline Gambit
Re: Fitting Armrest
« Reply #5 on: 16 January 2007, 08:59 »
only armrest worth having is the kamei one - the rest are all tripe fit as already said
Offline _MaVeRiCk_
Re: Fitting Armrest
« Reply #6 on: 16 January 2007, 09:35 »
It is gonna fit well once I have moved the seat adjusters, just dont know how
Re: Fitting Armrest
« Reply #7 on: 16 January 2007, 10:03 »
swapping the seat backs over is the easiest way, only some push pins on the trim and 2 C clips, then the backs come off the base! swap em over and then bobs yr uncle ;)
Offline _MaVeRiCk_
Re: Fitting Armrest
« Reply #8 on: 16 January 2007, 10:21 »
Is that for a three door?
Re: Fitting Armrest
« Reply #9 on: 16 January 2007, 10:49 »
same for 3 and 5 door.  only difference is on a 3 door the tilt handles will be on the inside.
