Golf mk2
Nasty crunch into 2nd
Topic: Nasty crunch into 2nd (Read 3383 times)
lowgolf
Here all the time
20 January 2004, 19:43 »
I get a crunch when i put it into 2nd at anything above about 3000. Cars done 107k on origional box. Any ideas or just general recon?
<br /><br />Yeah!!!
Rob
Re:Nasty crunch into 2nd
20 January 2004, 19:57 »
my mk2 has always done it in second when cold
but i have heard it could just be a worn syncro
Blue MK2
Guest
20 January 2004, 20:02 »
Yeah common fault.
I avoid the 'crunch' by letting the revs drop before selecting 2nd then changing gear.
Dragon6
Here all the time
20 January 2004, 20:06 »
try swopping your gear oil for synthetic this can help a little
lowgolf
Here all the time
20 January 2004, 20:15 »
Yeah but when its only a 1.6 driver i need all the revs I can get to keep up with them damn horrible minging annoying saxo efforts.
Cheers oakie ill be down the shops tomorow
<br /><br />Yeah!!!
golfvr6
Guest
20 January 2004, 21:25 »
2nd gear worn synchromesh. Gearbox oil change might help a bit, hold the clutch down for longer when selecting 2nd when box is cold.
Gambit
Forum addict
Reply #6 on:
21 January 2004, 09:44 »
weighted shift rod of a mk3 rod change box will help dampen the crunch
i.e. its still there but you wont feel it as much
Weighted shift rod
part number 1H0711183
11.55 +VAT
Speedydub
Guest
Reply #7 on:
21 January 2004, 13:42 »
Mine does the same when cold. I avoid it by knockin it out of first, pausing, then putting it into second
Blue MK2
Guest
Reply #8 on:
21 January 2004, 13:46 »
Gambit. will this rod stiffen my loose gear change aswel?
Speedy Dub. I pause it too. Its dangerous on busy roundabouts thou
Last Edit: 21 January 2004, 13:47 by Blue MK2
Gambit
Forum addict
Reply #9 on:
21 January 2004, 13:53 »
all the rod does is add extra inertia to the throw of the gear change
if the actual stick feel loose then you probably need the bushes & relay shaft ball replaced, as well as the one at the bottom of the gear stick itself
have a read through this
http://www.4crawler.com/Diesel/ForSale/ShiftLinkage.shtml
Golf mk2
