Author Topic: A mild bit of MPG assistance please ;)  (Read 1971 times)
Offline Ben Lessani
« on: 12 January 2007, 22:32 »
Hello guys,
So, on my quest for sorting my MPG, my last results averaged out to be 20MPG on Shell V-Power on a '86 K-Jet 1.8 8v. It still seems pretty low to me, so I was trying to find out the best way of finding out what might be off.
First things first was just to query the diagnostics on the MFA, as I don't have any readings to go off. I found these here (http://www.golfgtiforum.co.uk/index.php?topic=48159.msg379431#msg379431), but I don't know where its a 16v or not. My intake vacuum is 239 regardless of throttle position or how long the engine has been running.
Am I safe to assume that maybe I have a clogged air filter, or a vacuum leak?
The car has just been serviced and seems to be running alright, no flat spots or anything like that - just the MPG that's off.
Help my wallet guys, whats worth checking?
Offline mattkh
Re: A mild bit of MPG assistance please ;)
« Reply #1 on: 12 January 2007, 22:52 »
Hi
A new air filter.
What tyre pressure are you using?
Offline monzablue16v
« Reply #2 on: 12 January 2007, 22:57 »
the results are for an 8v on the link. I have a major fuel economy problem as well I get about 200 miles to a full tank on my 88 valver, does your MFA work on the mpg setting? mine doesn't and I think that might have something to do with it. I have tommorow to fiddle with it sounds like a similar problem.
My air filter is fine don't know about Blessani's!! tyre pressure about 35psi I bought the stuff to clean it with k&n air filter.
« Last Edit: 12 January 2007, 23:25 by monzablue16v »
Offline Ben Lessani
« Reply #3 on: 13 January 2007, 07:18 »
I've got a K&N (although not been cleaned for a long while - but saying that, the car hasn't been driven either), and the tyres are all at about 31 PSI - spot on really. I'll open the airbox today and take some snapshots ;)
My MFA works to a certain extent, because I've had a tonne odd electrical oddities recently, I keep having to disconnect the battery, so the MFA keeps resetting. However, at the moment, on the AVG setting, my speed is usually off, 17 when doing mainly 30 (but I suppose it is average). My MPG is usually about 8. On the real time diagnostic settings, the MPG never stretches higher than 17, even on a downhill in fifth!
Offline Gambit
« Reply #4 on: 13 January 2007, 10:58 »
for £10/11.5litres of sainsburys SUL i get about 65 mile which works out about 25.7 mile to the gallon.
and thats in & around town driving in a 16v
Monza u must have something seriously wrong!!! also, ur tyre pressures should be 32f/30r
« Last Edit: 13 January 2007, 11:00 by Gambit »
« Reply #5 on: 13 January 2007, 22:33 »
worked my mpg out to be 24.7 today need to find a long 3mm allen key as mine appears to have vanished somewhere :( Halfords don't do them any more bugger!!
Offline Ben Lessani
« Reply #6 on: 14 January 2007, 00:46 »
whats the 3mm allen key for>
« Reply #7 on: 14 January 2007, 12:06 »
It's to set the CO to 2% have you seen this link yet? link
I'm going to double check everything tuning and timing wise to see if that makes a difference if not I might just throw it at a garage and get them t find out why it is so bad on fuel economy also thinking of changing the fuel filter.
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
« Reply #8 on: 14 January 2007, 15:44 »
i can get about 70miles on 10quid driving steady away
my mfa shows 34MPG
Offline Ben Lessani
« Reply #9 on: 15 January 2007, 01:25 »
right, ive just driven from glasgow to manchester 230 miles @ 65 mph (3:30 hrs), the fuel gauge only seems to have moved to just under 3/4 tank. So I'm ignoring that, when I fill up I will post my results ;) Oh, I used BP Ultimate this time for comparison to Shell.
