Author Topic: When the revs are up I can steer, when they're not, I can't!  (Read 1059 times)
Offline robster23
  • Now a VW Fox Owner.
Anyone had this problem with the Power Steering?
Plenty of fluid and no odd noises but when at idle it's obvious that there is no power steering but with some revs it seems to kick in! Is the pump on it's last legs?
Robster
It's urban right? That means it must be tougher, obviously.... ;-)
Offline monzablue16v
Re: When the revs are up I can steer, when they're not, I can't!
« Reply #1 on: 12 January 2007, 23:00 »
could be the belt is slipping or needs replacing if not I would say pas pump.
Offline chrutchy
« Reply #2 on: 12 January 2007, 23:54 »
that is your power steering belt for definate
i had this on mine
changed the belt and it was fine
Offline L6W VW
« Reply #3 on: 16 January 2007, 20:23 »
I've had similar prob with mine as I'm going to turn the steering locks and the battery light comes on then the engine goes to stall only happened 3/4 times in the last few months,would this be down to the same conclusion.
LOWER THE BETTER !!!
