Author Topic: Rust  (Read 2897 times)
StephenEggo
Rust
« on: 20 January 2004, 12:09 »
I'm wondering how easy is it to repair surface rust on an oak green mk2?
Offline jasonpi
Re:Rust
« Reply #1 on: 20 January 2004, 15:29 »
im gonna keep my eye on this thread as i need to do some surface rust...say i sand down a patch of rust would i use a primer to seal it or is there something you spray on before the primer to seal the affected area. if anyone knows what the hell im on about let us know
Offline Gambit
Re:Rust
« Reply #2 on: 20 January 2004, 16:49 »
get acid-etch primer, this protects against rust reappearing
Offline jasonpi
Re:Rust
« Reply #3 on: 20 January 2004, 21:16 »
cheers but would i be right in assuming that the proces is as follows acid etch primer> primer> then paint???
Offline Dragon6
Re:Rust
« Reply #4 on: 20 January 2004, 21:22 »
yep thats right bare metal,etch primer,couple of coats of high build primer,then your top coats,if its just very small blisters for a temp job to stop it spreading sand off the top rust and apply some of that Hammerite Kurust kind of stuff you can get from motor shops the kind of stuff that kills the rust and turns black as it reacts,works pretty good and the rust doesnt come back..
Speedydub
Re:Rust
« Reply #5 on: 21 January 2004, 13:43 »
Hmmmm...im not an expert lol.
But i would rub down then use jenolite. then use a rust resistant primer........
Offline jasonpi
Re:Rust
« Reply #6 on: 28 January 2004, 10:22 »
cheers guys
Offline cheech
Re:Rust
« Reply #7 on: 28 January 2004, 10:39 »
I did that on a mates car...take off the surface rust with different grades of paper, brush on some jenolite and leave......then sand it down and prime then paint!
Offline jedi16v
Re:Rust
« Reply #8 on: 29 January 2004, 00:07 »
big problem is metalics can be a b!tch to match  :(
Offline modulater
Re:Rust
« Reply #9 on: 31 January 2004, 17:42 »
I would pop into the coachworks and see if they could do you a good deal.
You never know unless you ask.
