Author Topic: Replacing Shocks and Springs......  (Read 2595 times)
Offline Len
Re: Replacing Shocks and Springs......
« Reply #10 on: 11 January 2007, 13:15 »
Had Spax springs and adjustable shocks on my other cars and find them great!
Plus they are British! :wink:
www.sas.org.uk
www.the-ace.org.uk
Offline patch900
« Reply #11 on: 11 January 2007, 17:05 »
Plan on replacing my shocks and springs and lowering in the near future and wanted a bit of advice.
Can spend up to ~£400-500. Would like to drop to 40mm maybe. What springs would people suggest ?
What else should I think about having replaced at the same time as I cant see the point of spending money to have the shock and springs replaced if the parts around them are still a pile of s***.
Bushes ?? mounts, what else and how much do these bits cost ??
Virtually everything I know about the workings of the internal combustion engine can be written on the back of a small stamp with a large marker
Offline SLIM-DUB
« Reply #12 on: 11 January 2007, 18:36 »
4 -500 get some sweet coilovers! you can find some at really reasonable prices and ud have alot of change to get some other cool new bits!  :wink:
<br www.vwwold.co.uk<br />PIMPASAT 20v se
Mint Finish!
Offline robster23
  • Now a VW Fox Owner.
« Reply #13 on: 12 January 2007, 18:43 »
I don't want too much of a drop so looks like Eibach! Do you needs lowered / shorter shocks too or would OE ones do the job? I think at this stage anything would be an improvement! Sadly my budge doesn't stretch to something clever!  :wink:
It's urban right? That means it must be tougher, obviously.... ;-)
Offline patch900
« Reply #14 on: 12 January 2007, 19:42 »
If I get some new shocks etc what else might need changing ?
Bushes arent expensive and I plan to change them but what else so I can price it up ?
Top mounts (just the front or  front and rear), bearings, bump stops ???
Car has done over 100K, advice appreciated
Offline robster23
« Reply #15 on: 14 January 2007, 18:04 »
So when changing the suspension I will also need to get:
Bump Stops
Front Top Mounts (Possibly rears too)
Dustboots
Anything else?
Offline boneybradley
  • Back in a Mk3...
« Reply #16 on: 14 January 2007, 18:23 »
you don't need new bumpstop's as I have shortened the original's and they work fine, also defo front top mount's as these are crap on mk3's and have a bearing in them which fail (but go for top quality one's by v.w or febi bilstein) and you can reuse your dustboot's (again I have) as long as they are still intact and not split. rear mount's are just a rubber bush and rarely need changing but check the condition and replace if needed.
Also if your shocker's have done 70'000 miles I would change them as they do get saggy and robster23 you said eibach was your choice, just remember they do 2 different set's 1 is -20mm (streetline)and the other -40mm(sportline)
and now she sit's 40mm lower...on sportline's
Offline robster23
« Reply #17 on: 14 January 2007, 19:02 »
That looks tidy Boney. Is that 40 all round? I think I have decided on a set from euro performance, 200 squids all in, Bilstein Streetlines. Budget stretch but I can't wait for the difference. Is it a driveway dooable job?
Offline patch900
« Reply #18 on: 14 January 2007, 19:26 »
Cheers bradley for the info - for me it will be new springs, shocks, front top mounts . I can re-use my dustboots as they are OK. Hopefully bump stops can use as well.
BTW - nice car  :cool:
