Golf mk2
Head Torque Settings
Topic: Head Torque Settings (Read 1097 times)
GaGti
06 January 2007, 10:58 »
Im refitting stretch head bolts on my 16 valver today.. can somebody let me know the torque settings for the
head and bolts
as i cannot find them stated in the haynes manual...thank you
knobby
Re: Head Torque Settings
06 January 2007, 11:06 »
http://www.iol.ie/~kilkennyhockey//BentleyManual/GE01/ch4.8.html
"Torque the bolts to 40 Nm (30 ft. lb.), in the sequence shown in Fig. 4-19. Repeat the sequence, torquing the bolts to 60 Nm (44 ft. lb.). Repeat the sequence a third time, tightening each bolt an additional 1/2 turn. Alternatively, this last step may be done as two 1/4 turns."
Look at link above for diagram, bolts have to be done in this sequence to ensure the head tight and level. Hope you have a good torque rench and some balls
the bolts feel like there gonna break each time you tighten them.
Hope this helps.
Knobby.
Last Edit: 06 January 2007, 11:08 by knobby
Old VW's never die...they just go faster!
turbodub
Here all the time
06 January 2007, 11:56 »
The 40-60Nm stages aren't too bad, the 180° stage after that can be a bit un-nerving but its vital you do that stage properly.
knobby
06 January 2007, 12:07 »
I thought i snapped one once, but it was my cheap "Bit" not the bolt that broke, Suggest using good quality tools.
GaGti
06 January 2007, 12:58 »
thanks lads!!....much appreciated
AudiA8Quattro
Forum addict
07 January 2007, 18:47 »
Always use new gasket and head bolts.
The bolts have to be tightened in that sequence or the gasket will not seal properly.
Golf mk2
