Author Topic: mk2 big bumpers  (Read 1327 times)
Offline vw-bob
mk2 big bumpers
« on: 05 January 2007, 20:42 »
for my recently purchased mk2 golf...am thinking of putting big bumpers on my driver...are they easy to fit and are there any brackets or extra parts that i will have to get to fit it??? sorry...maybe a simple question but this is first vw...first car at that
Offline roy8846
Re: mk2 big bumpers
« Reply #1 on: 05 January 2007, 21:03 »
Hope this is cool to post http://www.matey-matey.com/big_bumper_conversion.shtml and yes its very easy 4 bolts under the car and the bumpers slide on and off , by the way i did not support the engine as said in that guide and i found no problems removing/fitting  :wink:
Offline Lewy
Re: mk2 big bumpers
« Reply #2 on: 05 January 2007, 21:05 »
Your quite right Roy, there is no need to support the engine, and yes they are as easy as that - 4 bolts and shebang, you've a big bumpered Mk2!
Offline Neaty
Re: mk2 big bumpers
« Reply #3 on: 06 January 2007, 01:14 »
make sure the big bumpers come with the proper brackets as the small bumpers ones dont fit. as i discovered when putting them on my driver a few years back
Offline vw-bob
Re: mk2 big bumpers
« Reply #4 on: 06 January 2007, 09:15 »
cheers for your help...shud get it done once i gt paid  :smiley:
Offline T_J_G
Re: mk2 big bumpers
« Reply #5 on: 06 January 2007, 11:03 »
huge +1!
If you're after indicators for the BB then i've got an orange set for sale and some white ones (like in my signature) in for sale section.
You'll need the 4 (2 on front 2 on back) little slide clips that the bumper slides on to. And probably an indicator loom unless you're handy making your own.
http://www.golfgtiforum.co.uk/index.php?topic=21645.10
Tim
« Last Edit: 06 January 2007, 11:54 by T_J_G »
Offline kniterider
  • had most, sold most and often buy more!
Re: mk2 big bumpers
« Reply #6 on: 06 January 2007, 20:40 »
thing to watch when removing mk2 bumpers is that you undo the bolts (17mm i think ?? ) very gently... too hard and fast and you can crack the corroded nutt that pressed/welded to the bumper frame loose.... then its a right @rse of trying to drill out the old bolt and stuff.. hopefully its all good and it will come out easily... this is just from my experience!!
 :cool:
