Author Topic: Re: Mercedes C-class alloys onto a MK 2 Jetta  (Read 1059 times)
Offline Bonzo1
« on: 04 January 2007, 22:57 »
Hi Guys,
Just wondering can this be done without major work?
I have seen a set of 16" C-class alloys (5 stud) available and was wondering who would do the hub adapters for this and what sort of money would they cost me?
All feedback appreciated.
Kind regards,
Bonz.
Online jv
  • Administrator
Re: Re: Mercedes C-class alloys onto a MK 2 Jetta
« Reply #1 on: 04 January 2007, 23:02 »
You are needing to adapt 5/112 wheels to 4/100 fitment. Adapters for this are not readily available because the general view seems to be that it is not safe. You could use two sets of adapters to go say 5/100 first but that is a shocking bodge really.
Most Merc wheels are also pretty low ET - say 30. So once you fit your adapter you are at a very low ET 5-ish which equals major arch work.
You could switch to 5/100 hubs and do it that way - probably the best way really.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline mase
  • mk3 madness!!!
« Reply #2 on: 05 January 2007, 13:46 »
another thing to think about is the central bore.....
i dont kno wat it is for mercs, would it be the same as VW's and audi's... or possibly the same as BMW?
Quote from: Slick#13
I still see there is a distinct lack of b!tch tit getting outage.
...word
Offline Martz
« Reply #3 on: 05 January 2007, 15:23 »
Can it be drilled out by a local engineering firm?
Offline tobz.
« Reply #4 on: 05 January 2007, 15:30 »
Merc centre bores are all huge at about 66mm, I fitted some merc rims on my T25 as they were the only ones that didn't require bore machining. From memory vw/audi centre bore is something like 57mm.
You got any pics of your dad's split ?
