Author Topic: supers or super 4s??  (Read 2398 times)
Offline rowlers
  • I'm back - MK7 GTI
« on: 03 January 2007, 19:31 »
Think I'm due some new plugs, the last lot are all black with oil and carbon caused by cr@p/kn@ckered stem seals...
they are currently Bosch supers, is it worth getting the super 4s? Or are there any others I should consider?
Any one remember the price of supers from VW?
cheers
Offline Agreeable Slick
  • Unit
Re: supers or super 4s??
« Reply #1 on: 04 January 2007, 01:58 »
Spark plug is a spark plug at the end of the day. The super 4s just means that they last longer as the electrode deteriorates then the spark will jump to the next closest one.
Whichever ones make you happy.
Offline rowlers
« Reply #2 on: 04 January 2007, 17:23 »
i've heard that before, single electrode ones works as well as others :wink:
I'll get the std ones from vw!
cheers
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
« Reply #3 on: 04 January 2007, 18:32 »
i all aways get super 4's
i dont think you can beet them. never had a problem
what ever you do though never use splitfire's they cause a world of problems.
yes super 4's is deffo the way to go
Breaker
« Reply #4 on: 05 January 2007, 09:39 »
i use super 4's as well and for less than 15 a set its worth it
they do improve throttle response
« Reply #5 on: 05 January 2007, 11:23 »
problem with single probe is because of the design the gapping tends to out of spec due to the boxes being bashed about in transit.  My maye has had loads of problems with this, so I'd always go with tripple probe.  Std 16v plugs will be tripple probe anyway though ;)
Offline rowlers
« Reply #6 on: 05 January 2007, 17:28 »
over £20 a set though from VW, will ahve to order from vwspares.co.uk!!!
Would sh|tty plugs cause this juddering I seem to have at 2k revs? - only does it if i hold it at a steady 2k (out of gear), or coasting with my foot just on the gas to maintain speed (any speed, any gear) at 2k revs?
will change them anyway for the sake of a tenner, even though thye have only done 10k miles!!
« Reply #7 on: 05 January 2007, 17:40 »
Yeah thats where I get all my service bits from :)
Not sure on the juddering though, but as you say worth a go.
Offline rowlers
« Reply #8 on: 05 January 2007, 17:45 »
it feels like a misfire, so I'll mabe try a cap and arm while I'm at it, last ones were just cheapies from local factors!
  • Unit
« Reply #9 on: 05 January 2007, 17:55 »
That's the funniest thing i have read all week.
