Author Topic: 8v water pump  (Read 1247 times)
Offline Ktuludays
8v water pump
« on: 02 January 2007, 22:36 »
my water pump has started to leak on my 91 8v gti.
i am going to change it but noticed on etos that there are two part numbers listed.
both items look and are described the same but one is nearly £80 and the other nearly £30
does anyone know why they differ so much and which one is correct?
037 121 010 C  74,68 GBP  water pump with sealing washer, without pulley, thermostat and
adapter
or
026 121 010 CX 28,00 GBP water pump with sealing washer, without pulley, thermostat and
adapter
both are listed for PB engine.
any help guys?
<br /><br />What don\'t kill ya, makes you more strong!
Offline turbodub
Re: 8v water pump
« Reply #1 on: 03 January 2007, 02:28 »
The expensive one will be the complete pump. The cheaper one will be the impeller/pulley side of the pump only.
Offline Organisys
  • Old and Slow...
Re: 8v water pump
« Reply #2 on: 03 January 2007, 22:45 »
Fitted a complete GSF pump on my 8v. still going fine after a year. lot less $
Offline Uku
Re: 8v water pump
« Reply #3 on: 04 January 2007, 17:01 »
aye same here . my gsf one is 2 years old and still fine , there as good quality as the vw ones , not alot to them really so save yourself some cash and get one from them or eurocarpats.
