Author Topic: Mileometer and Trip Computer Not Working...  (Read 2044 times)
Offline GaGti
« on: 02 January 2007, 13:59 »
Well my mileometer and my trip computer has given up the ghost...Im not sure where the problem could lie...The trip computer lights up and switches fine but the MPG and everything else constantly stays the same.. And my milometer doesnt move at all....Just wondering if anyone has any ideas of how i can fix it?
Offline VapourTrails
Re: Mileometer and Trip Computer Not Working...
« Reply #1 on: 02 January 2007, 15:29 »
by mileometer do u mean in the digital display or the one in the speedo? and didnt by anychance jump start it recently?
Offline GaGti
« Reply #2 on: 02 January 2007, 16:09 »
Its the one in the speedo that counts total milage...and nope i havent jumped started it the batterys fine :huh:
« Reply #3 on: 02 January 2007, 16:19 »
do you get any reading on the mfa or is it completely blank? it sounds like it maybe need replacing
the mileometer runs off the speedo cable or so i thought so if ur getting speed readings and they seem ok the internals of the mileometer may be buggered, the trip computer gets its readings using an air pipe which plugs into the back of the dash, and i think goes to the gearbox not 100% sure on that one. also the obvious thing is electrics fuse checking etc...
Offline GaGti
« Reply #4 on: 02 January 2007, 16:30 »
I get a reading but it seems stuck on the same reading if u get me? asif its froze.. there is power going to the mfa which tells me the fuse is fine..is there a battery behind the clocks? as some cars have lithium batterys behind the clocks which power the clocks sometimes they need replacing? ill check the cable from the milometer and trace it back, i need to change the dash bulbs anyway...going to be fun lol! any suggestions?
« Reply #5 on: 02 January 2007, 20:06 »
if you mean the numbers in the speedo, this is mechanically driven from the speedo cable.  If the spedo still works this means something has broken inside the dash, have a read of this:
http://www.4130-products.com/step/odometer/index.htm
« Reply #6 on: 03 January 2007, 00:28 »
i think the mfa needs the mileometer to work inorder to give out right readings check out johnnys link there aint much he dont know about a  mk2
Offline GaGti
« Reply #7 on: 03 January 2007, 01:26 »
Ty Lads Will Have A Read  :smiley:
« Reply #8 on: 03 January 2007, 07:59 »
the mfa gets a feed from a sensor screwed into the back of the speedo, if this isn't working the avg speed, trip counter and mpg display will not work correctly :)
