Author Topic: PAS help now with pic  (Read 1386 times)
Offline ed325i
« on: 30 December 2006, 21:13 »
Just fitted PAS to the golf 8v gti. In the kit I was given to pulleys one for the bottom and one for the water pump, I have fitted these but cant see how the alternator is driven   :embarassed:
All the other pulleys line up but not the alternator.
« Last Edit: 31 December 2006, 10:22 by ed325i »
Breaker
Re: PAS help
« Reply #1 on: 30 December 2006, 22:15 »
the alternator is driven by itself on a seperate belt.
straight off the crank pulley i think on only that one
Offline ed325i
Re: PAS help
« Reply #2 on: 31 December 2006, 10:22 »
This is the proplem
Offline ed325i
Re: PAS help now with pic
« Reply #3 on: 31 December 2006, 12:45 »
This is now sorted  :smiley:
Offline Uku
« Reply #4 on: 31 December 2006, 17:34 »
aye hehe its obvious the problem and for others reference theres a second pulley which is missing on the picture which sits inside the other one on the crankshaft , you can clearly see theres a spacer there instead on a non pas car.
Offline MK2 GTD
« Reply #5 on: 01 January 2007, 19:44 »
Is it me or does that cambelt look a bit dodgy  :shocked:
Offline Agreeable Slick
  • Unit
« Reply #6 on: 01 January 2007, 20:02 »
I was thinking that, looks like it's split in halt along it's length.  :undecided:
Offline ed325i
« Reply #7 on: 01 January 2007, 21:27 »
The cam oil seal has gone leaking oil all over the cam belt  :sad: so the seal and the belt have got to be replaced.
