Author Topic: What oil????  (Read 3193 times)
Speedydub
What oil????
« on: 19 January 2004, 12:28 »
Mornin all
I am wondering what is the best oil to use in my 86 8v golf...? Gonna have a go at changing it myself..... :o
Offline Gambit
Re:What oil????
« Reply #1 on: 19 January 2004, 13:08 »
10w30 or 15w40 will be fine
the sump bolt is a 17mm, make sure you get a new copper sump washer when you get your oil filter from VAG
Speedydub
Re:What oil????
« Reply #2 on: 19 January 2004, 13:10 »
Cheers, any particular brand I should go for????
Offline Gambit
Re:What oil????
« Reply #3 on: 19 January 2004, 13:52 »
get Silver Synta from VAG, semi-synthetic, cheap and perfect for your car
golfvr6
Re:What oil????
« Reply #4 on: 19 January 2004, 17:20 »
get synta gold or silver
the sump bolt is a 19mm  ::)
turbo
Re:What oil????
« Reply #5 on: 20 January 2004, 06:18 »
if you can get hold of vavoline maxlife then get this its the most amasing oil ever!
the vr6 had a oil leak coming as there was oil spots apearing on the drive and i needed to top the oil up so 500ml went in and the oil leaks stopped ;D
its due for an oil change ive got some maxlife ready to go in it!!! my gti is on 196000 miles now i ve got this oil i wont use anything else!
golfvr6
Re:What oil????
« Reply #6 on: 20 January 2004, 11:48 »
do you work for valvoline?  :D
Offline modulater
Re:What oil????
« Reply #7 on: 20 January 2004, 23:42 »
A lot of recent VW filters I have bought have had a new copper washer in the bottom of the box.
And it is 19mm
« Last Edit: 20 January 2004, 23:42 by modulater »
Offline winstonb
Re:What oil????
« Reply #8 on: 21 January 2004, 06:24 »
no one recommending non VW oil then, such as that fancy Mobile Magnatex or what ever?  or is the VAG stuff just really cheap?
Omar
Re:What oil????
« Reply #9 on: 21 January 2004, 09:13 »
I change mine for Castrol Magnatec every 6000.
I dont think its worked wonders but the advert has made me feel better about doing my short commute to work  :-\
Is there much better stuff out there I should be using??.....or is it fine to stick with the Magnatec??
