Author Topic: Doh! My car now sounds like its been turbo'ed  (Read 1416 times)
Offline Ben Lessani
« on: 29 December 2006, 23:38 »
The silly car of mine has yet again decided that it hasn't had enough money spent on it and decided to lose a part.
From what I gather, there is a yellow hose, which connects to the throttle body and the overrun cutoff valve - but the 90 degree rubber union has abandoned ship somewhere on the A74 (if someone finds it, please pm me to post it back to my address). You would never believe it, but the noise it makes is phenomenal when you're doing about 50 mph, a very loud hissing from under the bonnet! I'll need to pop down the dealership to get one ordered in, but the engine seems to be running fine in the mean time. Only thing I've really noticed is pants mpg, it used 3/4 of a tank for a 215 mile motorway journey @ an average of about 85 mph. I never really got a full gauge on how good the mpg is on the car because I've only done about 1000 miles in it since having it, and so its been difficult to judge, especially with the super lazy petrol gauge which takes about 5 mins to actually show a fully tank!
Will reconnecting this hose help my mpg woes? Also what might help brighten up the mpg front? I've got perfect inflated tyres, using Shell V-Power (99Ron I think), just had a service (cleaned up sparks - they looked fine to me, oil change and and belts).
Ben
Offline mk2mark
Re: Doh! My car now sounds like its been turbo'ed
« Reply #1 on: 29 December 2006, 23:50 »
Where are those extra spark leads coming from :shocked: :laugh:
Offline Ben Lessani
« Reply #2 on: 29 December 2006, 23:58 »
Lol  :laugh:, its an old photo (from my project page) when I was still fixing up the car, but it was the best one I had which showed the vacuum inlet.
Offline mk2mark
« Reply #3 on: 30 December 2006, 14:32 »
I actually just had a similar problem I think, unless I've read it wrong - I just robbed the rubber bit off the vacuum line for the cold start thing in the airbox.
Offline Uku
« Reply #4 on: 30 December 2006, 20:10 »
Quote
hehe that'll burn fuel pretty quick , once you pass 60-70 mph the drag/resistance is much higher and hence fuel consumption goes up , also the fuel gauge is not a good guide , 3/4 of a tank can be anything from 20 quids worth up to 35 quids worth on a golf , better to work out from the amount (cash wise) you put in once its almost empty.
« Reply #5 on: 30 December 2006, 20:17 »
stuff summat in the throttle body side of the hose to block it up, that should help in the short term.  you've got a massive air leak :)
Offline Ben Lessani
« Reply #6 on: 31 December 2006, 09:42 »
Will just be ordering the bits from the dealership, heres the part numbers off Etka for anyone else's reference.
034 133 784 - angled hose for overrun cutoff valve
Offline Ben Lessani
« Reply #7 on: 09 January 2007, 13:32 »
So I filled the gap with the proper connector and hooked it back up to the overrun cutoff valve. However, my MPG hasn't improved at all, still running at about 8mpg on super conservative driving, and 7mpg on thrashing it.
Again, I still need to fill the tank to check what I'm actually doing instead of going off the MFA, but I'd love to sort it out properly!
Ben
