Author Topic: Mk2 subframe  (Read 2106 times)
golfvr6
Mk2 subframe
« on: 18 January 2004, 23:44 »
Can you remove the rear bracket on the subframe that holds the anti-roll bar bush, or is it part of the subframe?
Veedubgt18v
Re:Mk2 subframe
« Reply #1 on: 19 January 2004, 02:19 »
pretty certain its all one unit, have a look on mine 2moro
turbo
Re:Mk2 subframe
« Reply #2 on: 19 January 2004, 02:22 »
yes you can when you undo theses bolts just make sure the jack is under and supporting the subframe
this is what it says in the haynes......
i suppose this is to stop other subframe mounting bolts being under stress! those other 2 bolts either side of the front struts etc.....
Veedubgt18v
Re:Mk2 subframe
« Reply #3 on: 19 January 2004, 02:26 »
Doh! its dark ok!  :-[
turbo
Re:Mk2 subframe
« Reply #4 on: 19 January 2004, 03:11 »
i for give you ;D
i can remember you can as i had to renew my front subframe as mine had cracked....
i let the garage do it as its a big job i can remember cleaning it up as it was from the scrappers and it didnt have the brackets on it so yes they do come off!!!!
thats thats........ ;D
golfvr6
Re:Mk2 subframe
« Reply #5 on: 19 January 2004, 17:19 »
cheers lads
just ordered the bits from vw  :D
